주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Lumix DMC-G7은 2015년 5월에 출시된 보급형 미러리스 렌즈 교환식 카메라입니다. 이 카메라는 16MP 해상도를 지원하며 4K 영상 촬영이 가능합니다. 모델 번호는 전 세계 대부분 지역에서 DMC-G7이며, 유럽에서는 DMC-G70입니다.
None of the back buttons work
Have you found a fix for this? I ran into this exact same problem. Fixed a loose piece in the camera and now the buttons won't work.
Update (10/18/23)
The entire inside element that holds the lens as well as the sensor was loose. So the lens and sensor wiggled around. I took it apart and put in two small screws and that fixed the issue. At work we have 4 G7s, and theyre all slowly giving out.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@joelvanbeek same camera Lumix DMC-G7? What part did you fix?
댓글 달기
답변 1개
@joelvanbeek try the service code on your camera to see if there is an error code. Make sure that after your work on your camera, that both Flex cables are properly re-connected and that the mainboard is free of any corrosion etc. Also make sure that you check the connectors for the flex cables. Remove the cables and then restart them. Check the ends for any tears etc. Here is the SM Panasonic DMC G7 that will help you with the diagnostic as well as the service for your camera. Let us know what you find.
There is of course always a possibility that this is Firmware related, but check the parts etc. first.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joel Van Beek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 421
