주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion x360 14(구체적으로 14-dw1010wm)는 360º 회전이 가능한 14인치 멀티터치 디스플레이, 11세대 인텔 프로세서, 인텔 Iris Xe 그래픽을 탑재한 다재다능한 2-in-1 노트북입니다. DDR4 RAM, NVMe M.2 SSD, 3셀 43 Wh 리튬 이온 폴리머 배터리가 장착되어 있습니다.
Screen replacement for x360
Hey everyone hope you are having a good day, has anyone ever replaced a screen on a HP Pavilion x360 ? If you could please show me a video or link a replacement that would be more than great!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
Hi @brandontunnell,
Please confirm the full model number of your laptop as shown on the product info label on the bottom of the laptop?
의 공유
hp pavilion x360 14dw1013tu
의 공유
댓글 달기
답변 1개
선택된 해법
Hi @brandontunnell
Here's the maintenance and service guide taken from this support webpage for the x360 14dw1000 series laptops.
Go to p.51 to view the procedure to remove the display assembly. On p.53 the LCD panel is being removed.
Also on p.53 you'll find the HP part numbers for the LCD panels that can be used. Usually the part number is somewhere on the back of the panel if you wish to verify which one you have now. Search online for the part number only to find suppliers that suit you best.
p.s. If you post the product number of the laptop (also on the info label) I may be able to find the part number for the screen so that you can order it before having to disassemble the laptop to find out what it is.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
Brandon Tunnell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 48
전체 시간: 1,348
