주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hisense H40은 395 ppi를 지원하는 48MP 메인 카메라를 탑재한 6.53인치 스마트폰입니다. 128GB의 대용량 저장 공간과 4GB RAM을 갖추고 있습니다.
My phone is lagging
My phone is lagging when I play games
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Hi @calebrajagopaul
Things to try to resolve the problem:
  • Wipe the cache partition and check if that fixes it.
  • Start the phone in safe mode and check. To start in safe mode with the phone turned on press and hold the Power button until the Power off option appears. Then tap and hold on Power off until the "Reboot to safe mode" option appears.
If it works OK when in safe mode, a downloaded app may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall, to check if it works OK or not. When it does the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed and wasn't already pre-installed on the phone when you got it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Caleb Rajagopaul 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 522
