주요 콘텐츠로 건너뛰기
A redesigned Pathfinder went on sale in late October 2012 as a 2013 model. Just like the second generation Pathfinder, it once again moved away from a body-on-frame, truck-based SUV and adopted a unibody design.
12 질문 전체 보기
4WD error: see the owner 's manual; after changing brakes
I have the error mentioned above after changing brakes. The car still drive but can't use 4WD. The light for ABS, traction control and "!" are on. How can I fix this? Nissan Pathfinder 2014 model
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Just started my ‘14 pathfinder, 30 degrees F, and same error message.
Did you get any feedback of the cause?
댓글 달기
답변 1개
@robertdraper @billy62801 common errors are anti-lock brake sensor or 4wd sensor or actuator at fault and will be needing to be replaced. However it can go as deep as the transfer case and 4WD module. I suggest you get it scanned and see what codes it shows.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Billy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 969
