주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6세대 Moto E 스마트폰입니다. 모델 번호는 XT2005-1, XT2005-3, XT2005-4 및 XT2005-5입니다.
What did I do wrong?
I thought I could take the phone apart and put it back together again but now it's stuck in some sort of boot loop and if it isn't in the loop I just see N/A in the corner. Did I break something or did I just forget to plug something back in?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@green36821 just to clarify, there were no issues with this phone prior to the disassembly. It functioned as should and now it does not. If that is correct, it sounds like there is either something that is not connect right. You will have to open it up again and check all the connection. Make sure they are properly seated and that there are no bend or broken pins.
It is also possible that this is a software issue. Which is less likely since your phone worked before, Let us know what you find out.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
so i took it all apart looked at everything and nothing seemed broken and its all plugged in but its still doing the same thing. is there anything else i should try or should i bite the bullet and bring it to a shop?
의 공유
댓글 달기
답변을 추가하세요
Green 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 25
전체 시간: 268
