주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 갤럭시 A04e는 큰 디스플레이, 괜찮은 카메라 기능, 일상적인 사용을 위한 안정적인 성능을 제공하는 가성비 좋은 스마트폰입니다.
Why does my battery run down too quick
Why does my phone battery run down too quick
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
@olumideadeyemi you are not giving us a lot of history here :-). It would be good to know what you have checked. A rapidly draining battery can be caused by software and apps. Make sure that you check your settings. Remove and/or turn any App off that you do not use. Check your network settings. Make sure that your phone is not consistently trying to search for a network etc. Same with push notifications etc. turn those off as well. Also, check for any software update for your phone. You can usually do that in the Settings menu
The other thing to consider is the battery itself. IF the battery doesn't take a full charge (it can even say fully charged on the phone) it will drain rapidly due to degradation. In that case, you want to go ahead and replace the battery. After that, re-evaluate your phones power performance.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
More details needed
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well Common Reasons for Fast Battery Drain on Galaxy A04e are:
  1. Running to many Background Apps running.
  2. High Screen Brightness
  3. Due to Outdated Software
  4. You may have Heavy Apps or Games install in your phone and that keep running in the background which consume more battery of your phone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Olumide adeyemi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 422
