주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire V5-471은 학생 및 일반 사용자를 위해 설계된 14형 보급형 노트북입니다. Intel Core 프로세서와 내장 Intel HD 그래픽을 사용합니다. 수리, 문제해결, 부품 교체 및 제품 사양에 대한 지원을 이용할 수 있습니다. 이 기기를 지칭하는 다른 모델명으로는 V5-471-6614 및 V5-471-6888이 있습니다.
change hdd to ssd problem
My Acer V5-471 laptop: I replaced the HDD with an SSD, but the laptop didn't work at all. The power button shows a blinking blue light quickly, and the laptop doesn't turn on. When I reverted to the HDD, it worked normally. Is there a solution or explanation for this issue?"
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@mustafameddah do you have an OS on the SSD?Since you did not give us a lot of detail, I'd check on this. It is possible that your computer does not detect an OS and treats the POST as a failed drive. You will need to set your BIOS to boot from something like a bootable USB drive and install an OS to the SSD
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
the ssd is new there is no os on it and it is not partitioned yet
the problem is that the pc doesn't turned on at all now bios shows up or nothing when it press the power button a blue light on the power starts blinking very fast that's it. i cant get to the bios or nothing else the screen black and the fans doesn't start at all
의
@mustafameddah but all that works again when you reinstall your HDD? If so, you do know that the issue is with the SSD.
의
@oldturkey03 yes because it's new and still not identify as mbr or gpt and still not partitioned yet i took the ssd and palced it on my desktop pc make it mbr split it to one part of 100 gb installed windows 10 and took it off and put the ssd again on the pc acer that it didn't work and it started normally thank you for the reply back
의
댓글 달기
답변을 추가하세요
mustafa meddah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 45
전체 시간: 480
