Why battery draining down fast
Battery draining fast
좋은 질문입니까?
Hi @aijazahmed
Try replacing the battery and check if that resolves the problem.
Here's a video that shows what to do.
Search online for B-H0 battery to find battery suppliers that suit you best.
이 답변이 도움이 되었나요?
First, check if the battery is bloated or not if it is bloated change it with a similar 4500mah battery.
If the battery is not bloated first change the app's background running setting to off from setting and stop other background processing you don't want.
Next, stop all unnecessary notifications and turn on the dark mode it boosts your phone battery life.
If it didn't work try replacing the battery and check if that resolves the problem.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 21
지난 30일: 95
전체 시간: 2,721
댓글 9개
Battery drains fast I am vivo phone
kishore kishore 의
@kishorekishore How old is your battery? Is this something new or has it been getting steadily worse? Have you considered @jayeff's advice to replace the battery?
Jerry Wheeler 의
Battery drain fast
Hashir Siddiqui 의
Battery draining issue
Gangadharaiah R 의
Very bad battery
Saguna Raghav 의
댓글 4개 더보기
