주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
압력솥, 전기밥솥, 슬로우 쿠커 및 기타 주방 조리 기구에 대한 수리 정보 및 분해 수리 안내서입니다.
F3 LED code on Aroma rice cooker
Hello I'm new to this forum so my bad if I break some rule.
I got an Aroma rice cooker
Model No. ARC-1030SB
Things been throwing up F3 error on the LED when I tried using it yesterday, now I did some digging around online and found out it's for something related to overheat sensors in the unit. Now as for as my knowledge goes I'm just an avg consumer (even though I hate to admit it) with no knowledge about how to go on with this, or even what to do to fix it, if that's even possible at this point.
I have already tried to typical plug, restart, plug back in couple of times
Already tried cleaning the thing to make sure there's no gunk
Already tried messing around with some buttons
So this is kind of my last ditch effort to post here before I add this unit to the global e-waste bin somewhere in the ocean and move onto a newer model. Any help or advice would be appreciated, thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
When did you purchase this rice cooker? If it was within 1 year then it is possible to file a warranty claim with Aroma.
의
That's out of question now, it's already heading to 1 and a half year. I would like to try and make an effort to manually try fixing the thing if that's possible with F3 codes. But I just don't see any guide or step by step process to doing that.
의
댓글 달기
답변 2개
가장 유용한 답변
Guide still a work in progress. Steps are all there, just need pictures and maybe a video.
Update - Feb 5, 2023 - I finished taking pictures and have refined the guide just a tad bit. But should be good enough to call it complete now. Feel free to let me know if anyone needs any clarifications or anything to add.
Aroma ARC-1030SB F3 오류 해결
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
@lolue I like it! very good and awesome of you to have done that. We appreciate that!
Repair is War on Entropy!
의
Thanks you !!! I had the same F3 problem and I already solved it.
의
댓글 달기
@jakeleo The F3 error shows as a : Top sensor short-circuit. Now we just have to find out how to tear it down and to find the sensor :-)
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
That's something but I don't know where to start, is there any step by step guide out there? cause I'm definitely willing to give it a try, just once again because of my limited knowledge in this tech I'm just lost.
의
@jakeleo post some good pictures of your rice cooker with your question. Let's see if we can figure out how to disassemble it :-) 기존 질문에 이미지 추가하기
의
Is there still a need for help with this? I have the same cooker and have fixed this issue twice. I can write up instructions and provide pictures if needed.
의
@lolue that would be awesome! Create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
의
@lolue Sure, it would still help if I can get any guide.
의
댓글 3개 더보기
댓글 달기
답변을 추가하세요
Jake Leo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 118
전체 시간: 6,038
