주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
식별 정보를 포함한 한두 문장의 짧은 설명입니다. 예: 2009년 6월 출시, 모델 번호 A1303으로 식별 가능.
Sound and tight during door open
Sound and tightness during door open
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @saravanan45237
What is the sound like? Also which door, freezer door or refrigerator door, you didn't specify?
Post a video where the noise can be heard as the door is seen being opened and closed, in your question. Here's how to do this in ifixit 기존 질문에 이미지 추가하기 Note: posting a video is the same procedure as posting an image.
In the meantime, if your model is an RM-3862, check if the door gasket is OK i.e. not broken, loose, warped etc or perhaps the door hinge (top or bottom hinge) is causing the noise and the door to not function correctly.
With the door gasket, check all around the problem door, especially on the underside where the gasket is less noticeable.
If it is the door gasket, search online for 3108704.382 to find suppliers that suit you best.
If it is a hinge, search online for 3850386016 to find suppliers that suit you best.
Here's the gasket kit installation guide and the parts list that may help
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Saravanan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 11
지난 30일: 27
전체 시간: 425
