주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 10월에 출시된 Samsung Galaxy A7 스마트폰의 2018년형 모델입니다.
My power button is not working
When I press my power button it doesn't turn on or off. How to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Power button is working but fingerprint is not working
의
댓글 달기
답변 1개
가장 유용한 답변
@muhammadal69023 you need to check the mechanical part of the power switch to make sure that it actually closes the contact. If that looks like it is working, then replace the power button flex. Since iFixit does not have a guide for this yet, use something like this for that. The power button flex also has the fingerprint sensor on it. It is readily available at many online stores.
If that should not resolve it, you will need to check your mainboard for a missing/failed component. Start with your power flex first.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Muhammad Ali 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 28
전체 시간: 800
