주요 콘텐츠로 건너뛰기
Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
20 질문 전체 보기
My phone speaker is not working
my phone speaker not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 2개
My phone battery is not charging
My phone blinks
댓글 달기
답변 13개
가장 유용한 답변
There are a few things you can try first:
  • Restart your phone. This is often the simplest way to fix minor problems.
  • Check your volume settings. Make sure that your phone's volume is turned up and that you're not in silent mode.
  • Clean the speaker grills. The speaker grills on your phone can get clogged with dirt and dust, which can block the sound. Use a soft brush or cloth to gently clean the speaker grills.
  • Update your phone's software.Sometimes, software updates can fix bugs that cause problems with the speakers.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
댓글 달기
Here are some quick fixes for a non-working phone speaker:
  • Check the volume: Make sure your phone isn't muted and the volume is turned up.
  • Restart your phone: A simple restart can often resolve software glitches.
  • Clean the speaker grille: Dust or debris can block the speaker. Use a soft brush to clean it gently.
  • Test with different audio sources: Try playing music, videos, or making a call to see if the issue persists across all apps.
If these don't work, the problem might be more serious and require professional repair.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Well check out the following: https://www.youtube.com/watch?v=vAG8B0Dx...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
One speker not work
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone speaker not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My mobile does not work
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Mobile speaker is not working
Update (06/25/24)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My mobile is not working
댓글 달기
Hello guys,
my phone doesn't vibrate, how can i solve that issue please.
TECNO CAMON15 premier.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Well Checkout the following video it might help you in fixing the issue:https://www.youtube.com/watch?v=W0-_BKzz...
댓글 달기
Check volume levels
Reboot your device
Adjust the app sound settings
Clear the speaker
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Charger not save
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Speaker not warking
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Screen is not touching
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
asfaw kefyalew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 29
지난 30일: 108
전체 시간: 2,222
