Why Video not visible
Their is not video and audio can be audible
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개:
Hi @shankar330,
What is the model number of the TV?
Can you view the TV menu screens OK?
What is the source of the TV signal - antenna, cable box, streaming device etc?
If it is not an antenna, have you proved that the signal source is OK by trying a different source e.g. dvd player etc or different input type e.g. HDMI, Component video + audio, Composite video + audio?
What have you tried?
의 공유
Their is no vision but their is no problem in audio
의 공유
@sowndaryjayaram you have not told us what you have checked. The no video issue can be related to a bad backlight inverter circuitry. A simple check for that would be to darken the room and turn the TV on. Then use a flashlight and angle the light at the screen on different areas. you might make out some shadows or see s slight grey color. Let us know what you find out.
we need the exact make and model etc.
의 공유
Black screen on tv but audio track is working
의 공유
@vincentpaulraj you have not told us what you have checked. The no video issue can be related to a bad backlight inverter circuitry. A simple check for that would be to darken the room and turn the TV on. Then use a flashlight and angle the light at the screen on different areas. you might make out some shadows or see s slight grey color. Let us know what you find out.
의 공유
댓글 달기
