주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sl510 Black screen display
The laptop is on but the screen is not turning on its just black what can I do please help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@manqoba start off by checking your backlight. To check your backlight use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If so, it is your backlight that has failed. either the LEDs or the backlight circuitry on your board will have to be checked.
Next attach an external monitor to your ThinkPad. IF that does not show an image as well, then the issue is most likely a bad GPU. If that shows properly you know the issue is with your LCD. Could be the display or even things like the display cable, display adapter etc. so let us know what you find out.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank very much for your assistance
의
댓글 달기
답변을 추가하세요
Manqoba 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 424
