주요 콘텐츠로 건너뛰기
The Kodak EasyShare Z740 offers an impressive feature set, easy-to-use controls, and a powerful zoom, making it a good choice for anyone looking for a simple camera with room to grow.
Kodak EasyShare Z740 wouldn't turn on.
About Kodak EasyShare Z740.
I haven't used it for a long time. I read on a blog that you can use regular AA batteries, so I inserted two AA batteries and turned it on, but it still wouldn't turn on. Does it need repair?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
This question was migrated from https://meta.ifixit.com/Answers.
댓글 달기
답변 1개
@cbhub7xx8xbyg2r make sure that you have good batteries. If it still does not come on, you will have to check the fuses on your main board. There are 3, labelled F1, F2 and F3. F1 should be the power fuse. Check all fuses for continuity. F1 and F2 are 1.25A, F3 is a 2.5A fuse
Use these guides Kodak EasyShare Z740 to work on your camera. There is none specific for the main board, so you will have to "experiment" a bit. Lucily the easyshare cameras are all pretty similar. Between the Z650 Kodak Easyshare z650 Teardown and the Z710 you should get this accomplished without to much trouble.
Post some good pictures of your boards etc with your Question. That way we can see what you see. While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
기존 질문에 이미지 추가하기
Kodak Easyshare z650 이미지
안내서
난이도:
조정
45 minutes
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
小池勝 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 103
