주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Yoga Slim 7 Pro와 함께 멀티태스킹을 마스터하세요. 세련된 14형 초슬림 노트북인 이 제품은 강력한 성능을 자랑하며, AMD Ryzen™ 5000 시리즈 모바일 프로세서의 초고속 성능과 매혹적인 옵션인 OLED 2.8K 비주얼, 긴 배터리 사용 시간, 그리고 하루를 알차게 보낼 수 있도록 도와주는 다양한 스마트 기능을 갖추고 있습니다.
My Camera Stopped Working
My camera randomly stopped working and my system says it is not connected. I have tried several software solutions but I think I might need to open it up and reconnect something...where can I find a guide to doing this? Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @ombreviews
Here's the hardware maintenance manual for the laptop.
Go to p.66 to view the procedure to remove the camera.
If the cable connection seems OK and the camera module needs replacing search online for either 5C20X55554 or 5C20X55556 to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
How can I check the connector on the motherboard? Before removing the screen or anything like that. I wasn't seeing anything in the manual for that. Thanks so much!
의
@ombreviews
Not sure with your model but nowadays a lot of the connections between the camera/microphone in the lid and the motherboard is done by a USB connection between the motherboard's IO chipset and a USB controller in the camera/microphone module. The two data wires for the USB are in with the video cable and not a separate cable.
All you can do is check how many cables come from the lid to the motherboard. Most likely there'll be the WiFi antennas connected to the WLAN card and a video cable and that's all.
You would really need to have the schematics for the motherboard to know exactly how it is connected.
I couldn't find a free schematic download online but if the board model number is an NM-D231 then you can purchase it here and it will show the wiring details
의
댓글 달기
답변을 추가하세요
OMB Reviews 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 15
전체 시간: 597
