주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Plug is broken at attachment point of device
The connection point has been badly damaged and now there is no sounds coming out
I'm hoping to repair the headphones
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi Lucy,
That's a fairly standard 3.5mm audio plug, although it's got three rings and a tip so it'll be marginally more difficult to find a replacement, but certainly not hard by any means.
That means there are at least four wires going to the plug, and you'll have to identify which wire goes to which band/tip on the plug in order to get it rewired to work correctly. In the spirit of iFixit, we'll be happy to try and help you do that, but first let me suggest an alternative.
Since the cord is completely detachable from the headphones, it makes a certain amount of sense that it might be available separately, and indeed, that turns out to be the case. I just did a quick search on Amazon and several cords came up that should all work; here's a representative sample that specifically says it will work with your headphones.
Amazon.com: Mr Rex Replacement Audio Cable Cord with Mic for Bose 700 QuietComfort QC35 QC35II QC25 QC45 Headphones, JBL E45BT E55BT E65BTNC 750NC Earphone, Nylon-Braided 2.5mm to 3.5mm Aux Cord Wire(1-Pack, 5ft) : Electronics
You can also check places like eBay and AliExpress where you may be able to find the parts even cheaper if that's a concern.
I present that as a labor-saving opportunity, but fully support you if you want to go ahead and try and repair your existing cord. Let us know and we'll see if we can go about finding a replacement and figuring out how to wire it up.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you. Have ordered the parts so we will give it a go
댓글 달기
@lucyjackson here is a guide for the repair of the jack including links to the parts as well as a listing for the tools needed to repair the connector.
4-Pole Headphone Jack Replacement
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Depending on your soldering skills, this one may be a little easier to work with, as it comes pre-wired.
https://www.amazon.com/Fancasee-Replacem...
댓글 달기
답변을 추가하세요
Lucy Jackson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 29
전체 시간: 347
