주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore 90 Series는 Kenmore에서 제조한 가정용 세탁기입니다.
Are timers still available?
Repair guy said that he can’t get a timer for my 90 Series washers is that true?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @daviddee42442,
What is the model number of the washer?
의
It may be true for him, as he might depend on a single supplier that doesn't carry the part you need. Nowadays it is much easier to shop an amazing number of sources for any given part, so the chances are good we can help you.
However, as Jayeff has already mentioned, we need the model number. Sears didn't make their own washing machines; rather they slapped their label on machines made by several different manufacturers, all of which could fall under the Series 90 category and have nothing to do with each other. So there's no way to get the correct part without the model.
의
댓글 달기
답변 1개
가장 유용한 답변
It depends on your model number. The Kenmore 90 Series Washing Machine has many different models and, as such, many potential different part numbers. Your exact model number will help find the exact part number you need, and then we can see if that is available or not.
Even if it is no longer manufactured or sold at major appliance parts retailers, one alternative method of sourcing the right part is to find a "donor device" from a used appliance store or from eBay (or similar). You can harvest a device with a working timer and use that for your existing device. This may or may not be economical depending on how much the donor device costs.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
David Dee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 330
