주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 TCL에서 출시한 32인치 Roku TV입니다.
No image black screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 16
댓글 13개
의
@edwinlombeh have you tried the steps listed in the answer?
의
the television does not turn on, but the power on light
의
No display only stay on
led indicator
의
Tidak ada gambar pas pakai sate box
의
댓글 8개 더보기
댓글 달기
답변 4개
가장 유용한 답변
@cristinejo80172 you forgot to tell us if you have sound. Next turn your TV on Then use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obviously damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 기존 질문에 이미지 추가하기 for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
이 답변이 도움이 되었나요?
점수 6
댓글 5개:
@oldturkey03 I have the same issue, and did the flashlight in a dark room.
Looks like a backlight issue. Any guides on how to replace it and what parts would be needed? Thank you!
의
yes me too can i get a guide on hoe to fix it
의
@rubimosqueda I bought new LED strips from Ebay.
And then followed these two guides from a youtuber.
https://www.youtube.com/watch?v=I32MBlbR...
https://www.youtube.com/watch?v=QdxSHeQF...
의
Full black image
의
@venu72785 what have you checked and what have you already tried?
의
댓글 달기
No enciende, estaba funcionando y se apagó y no prendio
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Black screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Ya ake amfani da wannan application
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
cristine joy catuboran 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 148
전체 시간: 5,486
