주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PIXMA MG6660 올인원 포토 잉크젯 프린터 수리 정보.
Where is the WPS button
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@ericliddell should be in your settings menu. It does not look like your printer has a physical button. Let's assume you are trying to setup a wireless connection. use the instructions from here You can also download the MG6600 series Manual from here It will help you with your setup.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Every printer I've had doesn't use a button, it's always in the network setting. Don't have a demo Canon, but I do it on the HPs from Network>Wireless setup wizard for the screen versions or WPS on some old 2-liner models. My gently used (with a bad imaging drum) monochrome laser uses the app under Network unless you enter it manually or use WPS.
I suspect Canon is similar.
의 공유
댓글 달기
답변을 추가하세요
Eric Liddell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 35
전체 시간: 400
