주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Poco F3는 120 Hz 주사율과 360 Hz 터치 샘플링 속도를 지원하는 6.67인치 AMOLED 디스플레이를 탑재했습니다. Snapdragon 870 5G 프로세서로 구동되며, 2021년 3월에 출시되었습니다.
USB port data transfer not working
Kind of weird story, I have bought this used phone which looked like new, after about 3 days and some weird problems like signal loss it died. send it to warranty and instead of changing the phone they have offered repair and charged me money for it. anyway after repair I am able to charge the phone and fast charge is working but I don't have data connection. my friend is a mobile technician and he said he changed USB/daughter board and also reballed CPU and still it's not working but ye also said that data would work for a very short period and then stop working again.
also I have some experience repairing phones if it matters.
Any help would be very appreciated.
Thanks in advance
best regards.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @zze76jg7jjvqoqg
When you connect the phone to a computer, is there a notification asking you to select the type of USB connection you want to use?
If not, I realize that you said that the USB daughterboard was replaced but maybe check the pins 30 and 32 in the 40 pin flex cable connector are OK
Here's an image from the schematics showing where the CC1 and CC2 pins (cable attachment and removal detection, receptacle/plug orientation detection, and current advertisement function) connect to as well as the resistors mentioned by the schematic i.e. R6501 1 and R6502 1.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
E A 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 23
전체 시간: 674
