주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Left speaker not working
How fix it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I need instructions on how to replace the cable that connects the two earpieces. With use, the cable that connects to the left earpiece is showing a loose connection and needs to be replaced. The main issue is how to replace the cable and route it to the other side.
의 공유
댓글 달기
답변 1개
가장 유용한 답변
@tonymak time to open both sides and check the wiring to the side that is not working. Make sure that the speaker wires are still connected. After that check the wire coming from the other side. Check that for continuity and check the solder joints. Make sure the the "springs" from the transducer make contact. To work on it and since iFixit does not yet have a guide for it, use something like this video and this guide JBL Tune 600btnc 배터리 교체 to at least get into it.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
If the left speaker is not working probably the internal sprints are not connected properly. This youtube video shows how to fix this: https://www.youtube.com/watch?v=jxVqfxQR...
However for me it did not help, but then I discovered that the other side also has a similar set of springs. In my case they didn't look corroded. With a small screwdriver I made the springs a bit longer (the ones at the right side) and lo-and-behold it worked.
See also this video: https://www.youtube.com/watch?v=igRC-jQp...
의 공유
댓글 달기
답변을 추가하세요
Tony Mak 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 30
전체 시간: 411
