주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
18배 광학 줌과 360배 디지털 줌을 지원하는 Canon MiniDV 캠코더
How to fix the glitch camera
I have just bought a canon ZR60A, it works great but the camera somehow have glitches all over, it shows on the lcd screen and the viewfinder. When recording, it records exactly what the screen and the view finder displayed before, which mean the glitch comes from the camera itself, how can I handle this
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
@sangnguyen66374 you need to be more descriptive as to what kind of glitch. We do not know what you are referring to when you just use that term.
의
Thanks, I've added the photo for a clearer point. I actually can still see the object, it's just that it has an extra layer of glitch and noise
의
댓글 달기
답변 1개
@sangnguyen66374 since it "records exactly what the screen and the view finder displayed" and it shows the menu but not what you are looking at, the error is most likely in the video circuitry and not coming from the CCD image sensor or even being an LCD error. Looks like IC903 on the LCD board is responsible for the LCD signal processing and drive. I would stay there with checking the circuit. Here is the Canon ZR 60 A Service Manual and you can use that to check the LCD PCB
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
So is it possible to find the replacement part if the problem coming from the cuircuit component error as you're referencing...
의
@sangnguyen66374 I would look for an LCD PCB and see if that resolves it.
의
댓글 달기
답변을 추가하세요
sang nguyễn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 37
전체 시간: 434
