주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2009년에 출시된 BlackBerry RIM의 캔디바 스타일 스마트폰입니다.
Signal Dropping when switched on?
When switching my device on I need to push the sim card with my finger to get it to actually get service. I used the device in the UK where 3g is still active however its an ex Verizon Model. is this a sim card reader error or a issue with the network on the device? Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @lewisjohnston
If you need to exert pressure on the SIM card when it is inserted, try sticking an appropriate sized piece of tape on the back of the card and then insert it.
Hopefully this will force the card to make better contact with the SIM reader pins due to the extra thickness.
Perhaps initially leave a "pull tab" as part of the tape on the back of the card, making it easier to remove in case it is now jammed in the reader due to the extra thickness of the card and you wish to remove it for whatever reason.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Lewis Johnston 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 24
전체 시간: 226
