주요 콘텐츠로 건너뛰기
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
Released in 2020, the Razer Blade 15" Advanced model is designed to provide gamers with powerful specifications and sleek aesthetics.
11 질문 전체 보기
Sourcing Screws to Hold In Battery
I'm hoping to get a battery replacement for my laptop which hasn't had a battery in quite some time. However, with several moves, the screws used to secure the battery have been lost. Is there any place I can find the battery retention screws, or even just something that works as a stand-in for them?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Depending on what kind of screws they are these might fit
https://www.amazon.com/Replacement-Screw...
I would advice checking the original screws that might be left or the screw holes in the laptop with a caliper to make sure they fit
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
The original retention screws were Phillips head, but I'll take whatever solution I can get. They're cheap enough that I'll buy them and give them a try. And while I don't have a caliper around, I do have one retention screw left I can compare them to.
@nathandavi62193 I would highly recomend making sure they are the right size first instead of finding out after spending money on it. Even if they are cheap.
댓글 달기
답변을 추가하세요
Nathan Davis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 6
지난 30일: 8
전체 시간: 83
