주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년에 출시된 이 F15 라인업은 Intel i5 또는 i7 프로세서, NVIDIA GeForce RTX GPU, 15.6형 1080p 디스플레이를 탑재하고 있습니다. 이 노트북은 세련된 디자인을 갖추고 있으며, 합리적인 가격대에서 성능 중심의 게임을 즐길 수 있도록 하드웨어가 최적화되어 있습니다.
Disconnecting Wifi and Bluetooth Automacically ,
Disconnecting Wifi and Bluetooth Automacically , even after reset the respected drivers , reinstallation of respected drivers , i tried everything by the help of youtube , but nothing helps .
" Disconnecting Wifi and Bluetooth Automacically occurs only whenever device is moved slightely " nothing happens when the device is remains in a same position !!!
this problem occurs only when the device is moved slightely or lifted or disturbed in its position !!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @deepak_
Do you mean that the WiFi and BT are just disconnecting or that they're intermittently not working anymore?
If just disconnecting try using the WiFi (or BT) as close as possible to your network router (or BT device) i.e <10cm and check if the connection remains stable.
If it does it may be a faulty antenna connection on the WLAN/BT card that is the problem.
If it still drops out or if it still fails etc it could be a loose or faulty WLAN/BT card.
Here's an image taken from this teardown video showing the location of the WLAN/BT card with the attached antennas.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Deepak_M 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 349
