주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
배설물을 위생적으로 처리하기 위한 장치입니다. 배관공을 부를 필요가 없어요! 변기 수리는 생각보다 훨씬 간단합니다.
Why is it leaking
My toilet seems to be leaking leaking and is soaking the carpet in my apartments bathroom (carpet in the bathroom is foolish but so is my land lord) It is not overflowing and I dont see any leakage at all. It seems that the water is flowing from under the toilet what could possibly be a good fix for my lovely throne.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
@ Old turkey Thank you for the advice I i will look at that this weekend and I will let you know how it goes then.
의
댓글 달기
답변 1개
선택된 해법
Michael Nicholas, I would lift the commode and replace the wax ring. It is possible that it is leaking. Not really a terrible bad job. Check this video as well as this one. It will give you a good idea. Make sure that it is seated properly and that there is not debris where the surfaces mate. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 6
댓글 2개:
Print and take this answer to your stupid landlord. It's his job to fix it and protect his property, not yours.
의
@mayer: Actually, it may depend from the jurisdiction where Micheal leaves. I can tell you for sure that some EU countries (as mine) put the ordinary maintenance duties (and the repair of the damages and the extraordinary-major maintenance and service intervention directly related to a lack of ordinary maintenance) to the tenant, and the major, extraordinary intervention to the landlord.
As a rule of thumb, when fixture and fittings are beyond a simple repair job, or they simply ceased abruptly to work with no possibility to fix them with a simple DIY repair (such as, in this case, a completely worn out wax ring, or a rusted float bearing in the toilet assembly, or a window with snapped hinges, or a wall showing cracks and fixtures, or leaking plumbing) not only the landlord has to fix them, but it's his duty doing so, and the tenant has the duty to keep him informed.
의
댓글 달기
답변을 추가하세요
Michael Nicholas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 35
전체 시간: 5,660
