주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
Troubles with new battery
I have changed the battery for a new one, but it does not charge 100%. The charge remains at 99% and does not reach 100% so I cannot calibrate the battery. The magsafe connector gets quite hot. So I don't know if it's a problem.
I use WATTS to see the health of the battery, but it shows me values as if it were the old one, except battery charge at 99%.
I followed the battery replacement guide, so I don't know what could be wrong.
Update (04/05/24)
이미지
이미지
이미지
Here are from 3 differents are the same results with differents programs
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Let’s use a better tool, I find this one is quite good CoconutBattery take a snapshot of the Apps main window posing it here so we can see.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@andresmend79046 - Well the replacement battery is not healthy either! I would recommend you return it to get another or your money back. Its likely this battery is a remanufactured one where someone took the cells apart check the discrete cells and then put the better ones back together to create a new battery. What does the battery info button tell you for the deeper battery maker info?
댓글 달기
답변을 추가하세요
Andres Mendoza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 19
전체 시간: 257
