주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Game Boy는 1989년 4월 21일 일본에서 출시되었고, 1989년 7월 31일에 북미, 그리고 1990년 9월 28일에 끝으로 유럽에서 출시되었습니다. 커다란 회색 케이스와 모델 번호 DMG-01이 특징입니다.
Game boy not turning on
I found my daughter’s Game Boy packed away in a bin in the basement. It’s been there for at least 15 years since she moved out. I thought my grandkids would like it. I cleaned the battery area and used new batteries but I can’t get it to turn on. The battery light doesn’t even come on. I called Nintendo and they no longer repair them. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@lorimaleko27985 the very first thing you want to do is to clean the battery contacts. Make sure they have not corroded to badly. If those are okay, you will have to disassemble your GB and take a look at the components. You could try and clean it with some isopropyl alcohol (+90%) and carefully check to see if there is anything obviously corroded etc. Until you have it apart, anything will only be a guess. Use Game Boy these guides to help you with taking it apart. Once you have it open, take a couple of well focused pictures and post those with your Question. That way we can see what you see and hopefully guide you further. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you. I just ordered a tri-wing screwdriver off Amazon and should receive it in a few days. I’ll let you know how I make out when I have it apart.
댓글 달기
답변을 추가하세요
Lori Malekovich Pluta 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 22
전체 시간: 204
