주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 8월 14일에 출시된 보급형 Realme 스마트폰입니다. 6.5인치 720p IPS 화면, Helio G35 칩셋, 최대 64GB 저장 공간을 탑재했습니다. 또한 Realme C11에는 없는 2MP 카메라와 지문 인식 센서가 추가되었습니다.
power button not working
pls help me out
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 17
댓글 9개
I inserted the speaker socket into my phone, and a minute later, the phone turned off and did not want to work. I tried cleaning the battery port and changed its screen, but it did not work either.
의 공유
Cara mengetahui kerusakan hp
의 공유
Camera problem
의 공유
@deepakchadar that is all you are going to give us? No make, no model. not telling us what the issues are, not telling us what you've tried, not telling us what you've checked? Only answer we can give you on this is replace the camera.
Once you add more information, we can always try and find a different solution but this is all we can do with what you gave us.
의 공유
Battery chang
의 공유
댓글 4개 더보기
댓글 달기
답변 2개
가장 유용한 답변
You should change the power button kit after opening it power button switch will cost you just 10rs you should go for it
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Tôi nghĩ bạn nên làm điều này
의 공유
how much would that cost btw?
의 공유
댓글 달기
@kxhbl8ukhdflfoj could be an issue with the actual power button not making proper connection with the switch. It is also possible that this is a bad volume & power button flex cable. Since iFixit does not yet have a guide for this, use something like this video or this one The second one is far more difficult since that applies a jumper across components.The repair flex cables are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Power boton not working
의 공유
@rajubiswas39784 follow the directions given in my original answer
의 공유
댓글 달기
답변을 추가하세요
D J 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 30
전체 시간: 1,647
