์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
๋‚ด ์ž‘์—…๋Œ€
๊ธฐ๊ธฐ์— ๋Œ€ํ•œ ์•ˆ๋‚ด์„œ, ๋ถ€ํ’ˆ ๋ฐ ๋‹ต๋ณ€์— ์‹ ์†ํžˆ ์ ‘๊ทผํ•  ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค
A modern air fryer that allows you to air fry, bake, and dehydrate your meals of choice. Model: Gourmia GAF536
1 ์งˆ๋ฌธ ์ „์ฒด ๋ณด๊ธฐ
E1 error appeared?not able to use it
E1 error coming
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
I found this:
The E1 error code on your Gourmia air fryer usually indicates a problem with the temperature sensor. This error code is often triggered when the air fryer's temperature sensor fails to detect a temperature reading.
Here are a few troubleshooting steps you can try to resolve the E1 error code on your Gourmia air fryer:
  1. Unplug the air fryer from the power source and wait for a few minutes before plugging it back in. This can help to reset the system and may clear the error code.
  2. Check to make sure that the temperature probe is securely plugged into the air fryer's socket. If it is loose, try unplugging it and plugging it back in firmly.
  3. Ensure that the temperature probe is clean and free from any debris or damage. If it is dirty, gently clean it with a soft cloth or brush.
If all of this does not solve it, then a repair is required and the sensor need to be replaced.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 2
๋Œ“๊ธ€ 5๊ฐœ:
Where the temperature probe its located
Hi! Please visit this website for images and further details: https://www.diynot.com/diy/threads/air-f...
The E1 Error Code Is Still Flashing & The A/Fryer Will Not Switch On ??
The bottom pan being in need of a good cleaning seemed to be the reason for the 001 error. I removed the tray to clean it, unplugged it, and replugged it in, the error code was gone.
Brand new air fryer, plugged it up and has the error code and nothing else will come on. Amy suggestions?
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Shobin James ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 14
์ง€๋‚œ 7์ผ: 55
์ง€๋‚œ 30์ผ: 202
์ „์ฒด ์‹œ๊ฐ„: 4,344
