주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A2159, EMC 3301. 보급형 13" MacBook Pro의 업데이트 버전입니다. 실버 및 스페이스 그레이 색상으로 제공됩니다. 2019년 7월 출시.
Original Battery not recognized
Hi,
I was assembling my macbook pro 13" 2019 and I have this problem: my macbook not recognized the original battery.
Have I damage the battery flex data cable? because, I pulled of this flex cable and I did not open the connector flex of the mainboard.
Photos:
이미지
이미지
이미지
Thank you,
Update (05/03/24)
Continue:
The only way to turn on my macbook pro is: connecting it to the electical network with my power adapter.
Thank you
Update (05/03/24)
Hi Dan,
Photos:
이미지
이미지
이미지
이미지
Update (05/06/24)
Hi
I have already had a new flex cable !!! and I have just fixed my macbook pro !!!
Thank you for all answers !!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
So the only way to use it is to plug it into the wall?
의
Exactly! That is the only way to use my macbook...
If I install Cocunut Battery... It will show "nan"
의
Both connectors seem to be fine and their tabs too, so is it possible that I have damaged the flex cable or the connectors of the mainboard?
I hope I have damaged only that cable...
의
댓글 달기
답변 1개
선택된 해법
Can you post images of both connectors so we can see if they are damaged. If it’s just the cable that’s replaceable MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
Replace the small flex cable that connects the battery daughter board to the logic board. 이미지
제품
$16.99
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Hi @danj,
Very close to being a short circuit between connector pins 9 and 10 (from the left) in the 2nd image posted above.
What do you think?
의
@jayeff - I would replace the cable for sure, but the real issue is what happed within the connectors.
의
@consu - Looking at the connectors they look OK, so maybe all you’ll need is a new cable! I wish you luck!
의
Thank you so much for your point of view!!
I will write here when I have the new Flex Cable.
의
댓글 달기
답변을 추가하세요
Consu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 28
전체 시간: 480
