주요 콘텐츠로 건너뛰기
TI-84 Plus calculator support.
20 질문 전체 보기
Sometimes doesn't turn on, also randomly goes off
I saw the issue for randomly shutting off. I'm not sure if the won't turn on is the same issue or a different one. I can hit the on button and nothing happens, but then after trying a few times, it will come on. It also randomly will shut off.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Try replacing all the batteries including the backup battery. There could also be a bad connection between the spiral wire contacts that connect the battery to the circuit board. Push gently down on the bottom left and right ones. that may make a more reliable circuit.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
R A 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 2
전체 시간: 32
