주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 255 G8 Notebook(모델명: 7N4W2AA)은 보급형 15.6인치 비즈니스 노트북으로, 일반적으로 AMD Ryzen 5 프로세서를 탑재하고 있습니다. 검색 결과에 따르면, 이 특정 모델은 일반적으로 8GB RAM, 256GB SSD, Windows 11 Home을 갖추고 있으며 일상적인 개인용 또는 업무용으로 설계되었습니다.
Laptop does not turn on
When the you switch it on the power light on for a second than goes off and the laptop does not not on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Could be a BIOS issue or could be a power issue.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter (yes, they make those for barrel connectors as well) and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
Now for your BIOS update and to check PC hardware diagnostics you would want to try the steps as outlined by HP in their HP 255 G8 Maintenance And Servcie Guide Let us know how it all works out for you.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jayzee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 368
