주요 콘텐츠로 건너뛰기
ThinkPad L13 (13”, Intel) Laptop Thin and light-13.3" display
Why my laptop won't charging?
My laptop won't charging. Charger adapter not problem, because when i use the same charger adapter to another L13 thinkpad it work properly.
When i plug the adapter to port usbc led indikator not turn on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@denykuswandi could be a lot of things and you will have to do a deep dive to do a bit more troubleshooting. You'll have to disassemble your laptop and check the USB-c port on the motherboard, check the USB controller and definitely check the battery. A failed battery does not get charged. Get an ammeter and see how many amps your laptop draws when it is plugged in. If it does not draw anything, or just minor amperage, it is most likely your battery.
Use the Lenovo Thinkpad L13 Hardware Maintenance Manual and we need to know what motherboard your computer uses. If it is a L13 1st gen, it should be a Wistron 18834-1N It'll be printed on the backside of the board.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Deny Kuswandi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 252
