주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 12월 1일에 출시되었습니다. 모델 번호 17ACH6H로 Lenovo에서 제조 및 유통하였습니다.
Integrated Camera disappears and appears randomly
The Integrated camera randomly disappears from Device Manager and randomly appears for a short time. It works when it appears, but it happens less and less. I tried different drivers and different OS, and tried switching the privacy shutter.
I took the laptop apart from the back to upgrade the SSD and clean the fans, but couldn't find the camera connector on the back of the motherboard.
It sounds like a connection problem to me (corrosion?). It happens often (several reports on Reddit with similar models) but no one seems to find a solution.
Can anyone help me find the connection port on the motherboard so I can check it? I suspect it is located somewhere under the keyboard and maybe just loose or damaged by moisture. If it is relatively easily accessible it could be easily fixed I guess. Or maybe it is located somewhere under the screen and requires screen replacement, then I won't mess with it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @borisnovikov
Without looking at the schematic¹ to know for sure, but nowadays the camera circuit is incorporated in the EDP cable (40 wire? video cable) between the motherboard and the display assembly.
It could either be 2 dedicated wires in the cable between the motherboard and the camera or it can also just be a 2 wire USB data link between the motherboard and the display assembly and then the camera is connected to a controller in the display assembly.
Here's the hardware maintenance manual for the laptop model series that might help On p.73 it gets to how to remove the camera module from the display assembly, so you can check if it is securely connected or not.
¹ Supplier example only as I couldn't find a free download for the schematic
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
dnnkeeper 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 518
