주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
TV started misbehaving (see video below)
TV is useless the image fades out all the time, see video below. is there anything I can do about it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
@letserherrera that is most likely a panel error. There is of course the slight possibility that this is caused by a overheating GPU on your main board but the way the picture fades, it's most common of a panel error. It is most likely a loss from teh LCD driver boards. You could try a Tape_off and see if that changes anything. Let's try something first. Remove the back panel. Then with the TV unplugged, remove one of the ribbon cables from the LCD driver boards. Now try and turn your TV on. Note exactly what your TV does. Then unplug the TV and reconnect the ribbon. Next disconnect the other ribbon, plug your TV in and restart. Let us know what you get with this.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you!, I'll try it as soon as I have a chance.
댓글 달기
답변을 추가하세요
Letser Herrera 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 153
