Problem with AC Alto K10
Getting hot air while using Air condition in Alto k10. What could be the reason for the same and how to fix it. Please suggest ๐
์ข์ ์ง๋ฌธ์ ๋๊น?
์ข์ ์ง๋ฌธ์ ๋๊น?
@anirudh2022 the very first thing you want to check is to make sure that you have enough refrigerant in your AC system. The issue with the Alto system is that it is a small system and you got to be careful if you get a recharge kit, that you do not overcharge the system. It is probably best to get the AC system fully evacuated and then recharged with the correct weight. For that, you might need to find someone who deals with AC in your area. The only other thing you need to check is your condenser (looks like a radiator in the front of the vehicle) and make sure that the fins are clean and that there is no debris etc. that impedes the air flow.
์ด ๋ต๋ณ์ด ๋์์ด ๋์๋์?
์ง๋ 24์๊ฐ: 5
์ง๋ 7์ผ: 10
์ง๋ 30์ผ: 43
์ ์ฒด ์๊ฐ: 1,729
ุชุฑููุจ ููุฑุจุงุก ุณูุงุฑุฉ ุงูุทู
Rebîdj AEk ์ ๊ณต์
@rebidjaek If this is a question, then you will need to add lots more information to it. Make , model and year of vehicle? What electrical installation?
translate
@rebidjaek ุฅุฐุง ูุงู ูุฐุง ุณุคุงูุงูุ ูุณุชุญุชุงุฌ ุฅูู ุฅุถุงูุฉ ู ุนููู ุงุช ุฅุถุงููุฉ. ููุน ุงูุณูุงุฑุฉุ ุทุฑุงุฒูุงุ ูุณูุฉ ุตูุนูุงุ ู ุง ูู ุงูุชุฑููุจุงุช ุงูููุฑุจุงุฆูุฉุ
oldturkey03 ์ ๊ณต์
Fiyul motar problam
Prince Rana Prince Rana ์ ๊ณต์
Not coling
Only fan
jignesh bhogayata ์ ๊ณต์
@jigneshbho50971 same as my original answer.
oldturkey03 ์ ๊ณต์
