Water is dripping from ac inside home
How to fix water dripping from ac inside the home ?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Hi ,
I received your problem right now that your AC is dripping water inside your room .
Firstly , I used to face this problem and I searched for a way to solve it , and finally I got the way to solve it . On the first step I did , “ it may work with you 95% “ is to go out the house and then going to the AC conditioning from out , and you will find a hose coming from the same ac . You must catch the hose in your hand then use to blow inside this hose hardly , the water will quickly get out the hose and some black dirt with it and wait for one minute then blow again hardly few times .
That was my opinion about fixing you problem and tell me if it work please by sending me a message on instagram , “ @1f0rs “
이 답변이 도움이 되었나요?
Problem with this is if you blow into the drain line from outside, you're blowing the clog back into unit. Might drain for a bit but is likely to clog back up. If there's a drain line to outside that is clogged, best to either use a wet/dry vac and suck the clog out, or blow it out from inside. Then the clog gets completely removed from the line and can't re-clog down the line
지난 24시간: 5
지난 7일: 36
지난 30일: 103
전체 시간: 1,202
Not sure which type you have, be it a window-type unit or a minisplit. If it's a window unit there's a drain usually from the evap drain pan to the outside. Might be clogged. If a minisplit then there's usually either a drain line (possible clog) or there's a drain line to a condensate pump. Could be clogged line or failed pump. Without more info on the unit it's hard to say
brandon k 의
سبب المشكل هو انسداد منفذ التصريف بالاوساخ
والحل هو :عليك بالتنظيف الجيد بواسطة ضغط الماء
احمد 의
