주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G29 Driving Force에 대한 추가 정보입니다.
I've got water damaged
The water was leaking in my house few weeks ago, and I think my G29 is water damaged. I haven't turned it on yet because I'm kinda scared if it breaks the main board. I'm currently living in NZ, how can I find if it is water damaged or not? or how can I find the logitech repair center?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @kfrshq1jiw4ldlt
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in its operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not connect power to or try to turn on your device to minimize any further damage.
Then you need to dis-assemble the unit and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a links that describes what happens. Electronics Water Damage
As always with electrical components and electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this it might possibly work correctly again.
Here is the ifixit Logitech G29 Driving Force repair guide that may help.
If this process seems too daunting, take it to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
baejunwoo1106 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 334
