주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 22일 출시된 Apple의 “더 작은” 2023년형 플래그십 스마트폰 관련 수리, 분해 및 문제해결 정보입니다. 6.1인치 프로모션 OLED 디스플레이, 트리플 렌즈 후면 카메라 시스템, 그리고 5G가 특징입니다. iPhone 14 Pro의 후속 제품입니다.
iPhone 15pro Non-Camera Modification
Hi,
I'm thinking of removing the camera from my current iphone 15 pro, cutting the back cover out of a flat sheet metal or titanium without camera protrusions and making it camera-less,
Can anyone who is a cell phone repairman etc. tell me what error do I get when I disconnect the camera from the motherboard in the iphone family and turn on the phone?
Does it give an error on the first startup and pass or does it give a system warning like camera is broken etc.?
or even worse, does it not boot at all?
Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I would consider myself an etc. So here's my take.
Believe it or not removing the camera is probably a non- issue. You'll probably get some warnings about the camera not being present, but those can be ignored. Replacing your back panel, however might come with some less fun side effects.
  1. No flashlight or wireless charging. They're part of the back glass assembly. And without the camera, the flashlight probably won't work anyway due to the way that circuit works.
  2. Removing the back glass is highly likely to generate an issue where the phone will reboot every few minutes. There is a sensor in the flex cable on the back glass that the phone is expecting check ins from. And if they are not present, it will just reboot (hoping I assume, it will be available after the reboot). Which might make your phone much less usable.
There are probably ways around the second item if you can move the wireless charge coil and all the bits attached to that cable to the new back panel. But that can be a tricky endeavor. And in the iPhone 14 and 14 Plus, where the back panel was redesigned, the original parts are needed to prevent the loop since there is some parts pairing at play. I haven't had an opportunity to check this yet, but I would fully expect it to do this on 15 series as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Michael Wick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 33
지난 30일: 170
전체 시간: 4,320
