주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung RF267 냉장고에 대한 수리 및 상세 정보입니다. 이 모델은 자동 제상 기능과 냉장 부분에 대한 서랍 및 도어 접근 방식을 갖춘 하단 냉동고형 냉장고로, 도어를 통해 얼음을 바로 이용할 수 있습니다. 이 페이지는 RF267**** 패턴과 일치하는 모델 번호에 대한 정보를 다룹니다.
Compressor Starting With Failed Start Relay? How Can This Be?
Three weeks ago, the freezer section of my Samsung refrigerator (twin cooling) just stopped getting cold. No warning or previous symptoms. No error codes flashing. None coming up during self-diagnostic. The fridge section is also only getting down to 50 degrees. Here's what I've checked so far:
- Set temps: Freezer -2, Fridge 34.
- Actual room temps: Freezer 70, Fridge 55.
- No icing on the evap coils.
- All temp thermistors tested accurate.
- All fans tested fine.
- Condenser coils clean, and fan working.
- 115V present on SMPS PCB. DC170 found at BD1 rectifier (good).
- 12V and 5V outputs on SMPS PCB good.
- Front panel seems to operate normally.
- Test mode works as it should. As does demo mode.
- Tried resetting several times and left unplugged for a couple hours. No change.
- Compressor starts fine. No unusual noises. No short cycling.
- No continuity when testing start relay (DA35-00103B, PTC thermistor). Relay resistance tested very high - 1.2K ohms at room temp.
- OLP tested fine.
- Run cap tested fine.
- The compressor also stops running before reaching set temps. This could be due to OLP kicking in.
Q. So, how is the compressor starting with a failed start relay?
Q. Could a failed start relay cause the compressor to start but not cool the unit effectively?
Attaches to the compressor and helps start the compressor motor. 이미지
제품
DA35-00135A - Samsung Refrigerator Compressor Start Relay
$104.99
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @ibreakit66745,
What is the model number of the refrigerator?
How long does the compressor run for after starting?
의
Thanks. It’s a Samsung RF267ABBP. Not sure exactly how long the compressor runs before stopping, but I do know it’s a long time - several hours. No short cycling. And it never reaches either set temps.
의
댓글 달기
답변 1개
가장 유용한 답변
Hi @ibreakit66745
Re the start relay - according to the service manual the resistance value should be 10 Ohms. Perhaps it is faulty and re-operating when it shouldn't thereby causing the OLP to operate.
How hot is the compressor getting?
Seems like there's a problem with the sealed system, either a lack of refrigerant or a compressor problem.
The manual doesn't specify the pressures only the type and amount of refrigerant in the system - see p.14
You may have to get the sealed system suction and high pressures tested to know what and where the problem is.
Depending on your location, you may have to get a licensed refrigerator repair service to do this, due to the environmental regulations regarding the handling of refrigerant gases. They also have the correct gear to do this.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
iBreakIt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 530
