주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Legion 5-15IMH05는 고성능을 위해 설계된 게이밍 노트북입니다. 게임, 프로그래밍, 콘텐츠 제작에 특화되어 있습니다. 이 기기 페이지는 사용자가 자신의 Legion 5 모델을 식별하고, 배터리 결함, 과열, 저장 장치 업그레이드, 키보드 또는 디스플레이 문제와 같은 일반적인 문제에 대한 공식적이고 신뢰할 수 있는 기술 사양, 서비스 문서, 수리 자원을 찾을 수 있도록 돕습니다.
My Ethernet Connectivity Issue
For some reason my ethernet stopped working, I tried a new ethernet cable and different router and it was still not connecting. After further investigations about the problem, it seems that my laptop itself is the problem. It would only say "no connection" how do I fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @christianmamon
What is the status of the LAN network adapter shown in Device Manager?
Go to Device Manager - Network Adapters - right click on the LAN adapter entry - Properties - General - Device status box.
Does it say, "this device is working properly"?
To get to Device Manager in Win10/11 press the Win key and the x key (both together) and click on the Device Manager link.
If it is OK try resetting the TCP/IP stack and check if it works OK.
If there's a red cross next to the LAN adapter entry in Device Manager, right click the entry - Enable and check if it works OK.
If there's a yellow exclamation mark next to the LAN adapter entry in Device Manager, right click the entry - Update drivers and follow the prompts. You need to be online for this procedure to work. Try WiFi perhaps.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Hello! will this work the same with "no internet access" problem?
의
@christianmamon
Not sure what you mean.
The above is just checking if the LAN adapter on the motherboard is working OK so if it checks out OK and you have reset the network in the laptop, all you can do is try it and see.
Have you checked that there's no "bent" or missing pins in the Ethernet port on the laptop?
의
@jayeff I have, nothing is missing, though Im concerned that it keeps going back to identifying even if it connected earlier
의
@christianmamon
If the adapter status is OK and you have reset the TCP stack there's a problem on the motherboard as it isn't connecting to the router.
의
댓글 달기
답변을 추가하세요
Christian Mamon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 59
전체 시간: 1,561
