주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A04s는 큰 디스플레이와 괜찮은 배터리 사용 시간을 갖춘 가성비 좋은 스마트폰입니다. 일상적인 사용을 위한 기본적인 기능과 성능을 제공합니다.
My phone looses touch
After some time I have to forcefully reboot my phone because the screen can't be touched
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@frankcheruiyot could be caused by the touchscreen failing or by the touch IC failing. I would start with the easier one which is replacing the display assembly which does include the touch screen. Since iFixit does not yet have a specific guide for that, either use something like this guide or this video The guide is written in French so use a browser that does the translation for you (if needed). Replacement display assemblies are readily available at many online stores.
Should a new display assembly not fix this problem, then you will need to check your mainboard. For that you will need some decent tools as well as the ability to solder very small components on a very busy circuit board. Let us know if that is something you would want to tackle.
Of course, a few other things before doing all of this is to check your software. Make sure that all of your software has been updated. If that does not help, consider doing a factory reset. Before doing that you will need to backup all of the files (SMS, Contacts, Music, pictures etc.) from your phone since all of those will be deleted. You also need the username and password for the google account you've used to originally setup your pone. If you do not have those, you can't easily access your phone after a reset.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
FRANK CHERUIYOT 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 291
