주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi CC9 Pro(글로벌 명칭 Mi Note 10) 안드로이드 스마트폰은 1억 800만 화소 카메라, 5260mAh 배터리, 6.47인치 곡면 AMOLED 디스플레이를 탑재하고 있습니다. 2019년 11월에 출시되었습니다.
Why power very fast loosing?
Why power very fast losing?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@badrulhish29324 there are many reasons that can be responsible for this. First you want to make sure that you use power -saver settings. This should work for your phone:
Slide two fingers downwards starting from the top of the screen. Press Battery saver to turn on the function. Press the Home key to return to the home screen.
If that does not accomplish anything, I would suggest you replace the battery. A depleted battery will tell you it charged to 100% but does no longer have the capacity it did when new. Replace the battery and re-evaluate.
Since iFixit does not yet have a specific guide for this, use something like this video Replacement batteries are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Badrul Hisham Mohd Norani 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 13
전체 시간: 169
