주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Compatible Touchpad Replacement Parts
I am trying to replace the touchpad as it has a constant Error code 10 when trying to connect, through reinstalling the drivers and updating them it doesn't work. Are there compatible touchpads from other laptops that I can use in place of it? I am having trouble finding a replacement touchpad which I believe is the problem.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @kylew87212
Check if there's a part number on the touchpad and search online for the number to find suppliers.
Here's the hardware maintenance manual for the laptop that may help.
Go to p.59-p.60 to view the procedure to remove the upper case with keyboard assembly, so that you can see if there is a part number on the touchpad.
The parts list for the model, doesn't show the touchpad as a separate item as it is most probably included as part of the C-cover with keyboard assembly. Click on Machine Type > Select Commodity to see all the available parts and their part numbers.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I looked up the part with the stickers on the back it looks like the vendor was CNY the P/N: was PK37B01FL00 P531003290000AEJ
it came up with nothing but I am probably going to look into what you mentioned because it would get me the part but the keyboard would be a waste unless someone brings me a broken keyboard.
댓글 달기
답변을 추가하세요
Kyle W 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 322
