주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One 컨트롤러는 2016년 Xbox One S 출시와 함께 소개되었으며, Windows 10/11용 블루투스 지원 기능이 추가되었습니다. 이 컨트롤러는 모델 1537/1697 컨트롤러에서 발견된 많은 설계 결함을 수정했으며 훨씬 더 안정적입니다. 이 컨트롤러는 개선된 모델 1914 컨트롤러로 대체되었습니다.
Left Stick Constant Input Down
I attempted some maintenance on my controller a couple of weeks ago, using some 99% IPA to scrub the potentiometers of the joysticks to my controller, as well as the joysticks themselves, and other areas of the motherboard. However, as a result, the left stick has been constantly giving input downward according to the direction of the stick.
I have attempted to clean the potentiometers again, as well as replace the left stick just today, to no avail on resolving this new issue.
Upon testing for continuity, I noticed that the pins in the potentiometer intended to input vertical LS movement do not seem to have a connection. This is after clarifying that all of the opposite pins on all three of the other potentiometers in the controller returned a status of continuity existing between them respectively.
I am wondering, then, what the problem could be with the controller. Thank you for reading into my inquiry.
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Aiden!
How are the solder pads? Still good? If those are damaged it can cause the issue you are having.
Also, check the other components near the sticks on the motherboard, maybe something is damaged there.
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Hi there, what could I do in the event that the solder pads are damaged? How could I bring the controller back to operation in such a case?
Depends on how it is damaged! Can you remove all the solder and sent us a new photo? Thanks in advance!
댓글 달기
답변을 추가하세요
Aiden 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 262
