주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore Elite HE3는 Kenmore의 세탁기입니다. Whirlpool Duet과 동일한 모델입니다.
Changed pressure switch, keep getting error code
I posted this earlier and didn’t get any responses so I’m trying again. I started getting an error code and was told the pressure switch was probably bad so I just replaced it. Tried doing a cleaning cycle but I keep getting a SUD error. Looking for help so my wife doesn’t just run out and buy a new machine.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @mcap20026
What is the model number of the washer?
의 공유
110 47789701
의 공유
댓글 달기
답변 1개
선택된 해법
Hi MCap,
Looks like you're not the first person with this issue that's had the same problem, so I'd say the place to start would be with the other guys who went through it.
SOLVED: Why am I getting a SUD error message? - Kenmore Elite HE3 Washing Machine - iFixit
In some cases the pressure switch fixed the problem, but there were several other cures that were found by various methods.
Finally, there's a technician's manual on the device page that has troubleshooting steps you can try.
Duet-Aid_also-Kenmore-HE3.pdf - iFixit
Give that a look and try some of the solutions then come on back and let us know what you found. We find that we can usually learn something from both successes and failures, so be sure to update your question with the results.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for the input. I can’t seem to find anyone who has had a problem where after a minute of running a SUD code will come up even though there isn’t any soap in it. I’m also still getting the F35 code after replacing the pressure switch. The tech guide looks like it’s for a dryer so I’m not sure if I can use it or not.
의 공유
@mcap20026 Ah crap, you are absolutely right; I didn't look past the title since it was on the washing machine device page. I've edited my answer to include the other manual from that page instead, which IS for a washer. Sorry, my bad.
의 공유
댓글 달기
답변을 추가하세요
MCap 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 263
