주요 콘텐츠로 건너뛰기
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
20 질문 전체 보기
Lens will not focus, it's not dirty
My sony w55 7.2 doesn't focus. i bought this off ebay to replace the original one i had previous that fell and now won't turn on and the lens is stuck in midrange. My new one that I am having trouble with right now is the one having capture issues. It picks and chooses when it wants to focus on an object/person in frame.
When pointing the camera at an object or a person it will not show a focused version on the screen. I thought initially it was because of sun exposure but it happens at night too. It doesn't focus on people and then randomly focuses. Distance is not a factor here because it displays a blurry image too when I am up close.
The camera was not having this issue when i bought it off ebay and it has not fallen.
What is it and how do I fix it without re-buying the entire camera again. (I still have the other broken one as well if there is an option to merge the two cameras!)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The range finding is done within the smaller lens closest to the top. Review this guide Sony Cyber-shot DSC-W55 Lens Replacement The last image within Step 10 shows its location internally, and then you can remove the full lens unit. I'm not sure if the focus module is replaceable on its own and you likely will need to go deeper. Using your other camera you might be able to swap it out.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Stephanie Barbosa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 162
