주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox Elite Wireless Controller Series 2는 2019년 11월 4일에 출시되었으며, Xbox One, X, S 콘솔은 물론 Windows 10/11을 실행하는 PC와 호환됩니다. 모델 1797.
Non-responsive with battery connected
Have a strange issue. My elite 2 controller is completely non-responsive when the battery is connected. Won't power on, charge, or anything. BUT it works when plugged in via usb without the battery connected. As soon as I reassemble the back plate and connect the battery, the controller is completely dead.
Useful diagnostic info:
  • battery is delivering power and not damaged
  • no liquid damage to controller
  • no visible corrosion on battery connectors
What is going on????
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Are you using a battery pack? Or just 2 AA batteries? Did you tried both to test the controller? Is the controller up to date? When using a battery pack, which brand? The one from Microsoft?
의
This is an elite series 2...the battery is built-in, not AA replaceable. The battery is original.
의
댓글 달기
답변 2개
가장 유용한 답변
Hi Matthew! Sry! Okay the easiest thing to try is a new battery pack and see if that solves it! If not, it’s motherboard related. Controller is up to date?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
The controller is up to date. I just put the controller back together and while securing the back plate onto the board housing the controller turned on. Once I screwed the back plate onto the housing completely, the controller is now no longer responsive. Could there be a faulty or loose connection? The three pin battery terminal doesn't appear damaged.
Thoughts?
의
Hi! Could be, or something is causing a short. Can you check if the screws are not touching the motherboard? Also check the cables to see if they are free when closing the back plate.
의
댓글 달기
Its possible you are screwing the screws too tightly wgen you reassemble the controller. Try to loosen them a little. It might work
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Any fix? I have one with the same problem
의
댓글 달기
답변을 추가하세요
Matthew Riordan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 60
전체 시간: 587
